SIP provider uses RTP 10000:20000
Discussion in '3CX Phone System - General' started by kalvik, Mar 11, 2017.
Tags:
  1. kalvik
    Jun 16, 2015
    5
    The question is how adjust RTP ports to include this range? Using 3CX 15.0.62928.5.
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    You don't need to adjust anything.
    Provider may use UDP ports 10000-20000 (probably an Asterisk), your 3CX PBX -- 9000-9255.
    Make sure you have forwarded ports correctly through your router and make sure 3CX firewall checker passes tests.
  3. kalvik
    Jun 16, 2015
    5
    Port forward 10000:20000 to 9000:9225
    Or
    Just a simple port forward
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Hi kalvik,
    The 3CX system phone works on the range of ports 9000-9255, so you need to open that ports to work properly your system. A simple port forward to your system. The range that mentioned above is used from other system probably from asterisk.
  5. eagle2
    Apr 27, 2011
    1,085
    11
    This will not work, sorry.
    On 3CX you need to forward destination address: port (public address: port) to local address of 3CX: port, in 1:1 relation -- port 9000 to 9000, 9001 to 9001, ... You need to test it afterwards with 3CX firewall checker.
    Ports in the range 10000-20000 are source ports (bound to source address of the other PBX / VoIP provider), not destination ports for traffic coming to 3CX.
    #5 eagle2, Mar 13, 2017
  6. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    That may be suspicious to provider. Imagine that ATA from provider is using that (first) range. We really need per trunk port range override?
  7. vectorpro
    Nov 8, 2016
    I have the same issue with my VoIP Provider. According to them the 3CX send RTP traffic under the UDP port 9000~9255... and it has to be on the range 10000~20000, is there something to do on the 3CX.?
