SIP Proxy for SNOM external extension with Static IP
Discussion in '3CX Phone System - General' started by wblake, Apr 15, 2010.
  1. wblake
    Jan 10, 2010
    I am reviewing the configuration of some external extensions that have had some reliability issues in our 3CX system.
    On the Web Page for Configuring SNOM Phones
    http://www.3cx.com/sip-phones/snom.html
    I read a Note that states:
    Note 4: There is a known issue with using SNOM Phones as external extensions about which we are in discussions with SNOM to find a resolution. If you need to use a SNOM Phone as an external extension, you will need to implement the 3CX SIP Proxy Manager on a PC in the remote location.
    Does this note still apply, and does the Proxy Manager still need implementation with SNOM phones that have Static IP addresses?
    Thank you,
    Wil Blake
  2. dapatter
    Feb 17, 2010
    53
    I am also seeing this problem....what exactly is the problem?
  3. dapatter
    Feb 17, 2010
    53
    Has anyone got any further information on what the exact problem is here?
  4. gsaccountants
    Apr 6, 2010
    31
    Does anyone know if the work has resulted in compatability for the new 821 coming later this month?
    thanks,
    alun :)
