SIP Proxy Manager v9 says v8?
Discussion in '3CX Phone System - General' started by brianp, Oct 21, 2010.
  1. brianp
    Aug 6, 2008
    45
    I downloaded v9 of the SIP Proxy Manager from your download page. The file is 3CXSIPProxyManager9.msi. But after installing when i go to Help/About it says v8.0.9674. Will someone confirm the version of this file?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Sounds like someone just messed up on the text there. Is it working correctly? That's really the only important thing.
