sip proxy manager with dyndns
Discussion in '3CX Phone System - General' started by gsaccountants, May 19, 2010.
  1. gsaccountants
    Apr 6, 2010
    31
    is there a way to specify a domain name instead of an ip address? we use dnydns to resolve to a dynamic ip address. thanks
    11,277
    360
    Will it not take anything but an IP address?
  3. gsaccountants
    Apr 6, 2010
    31
    does not like a fqdn only ip when i tried it.
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    You need to give it a static ip, changes in ip would drop calls constantly, if you wish you could all make a feature request.
  5. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    There are many things that fail to work correctly with FQHN and to top that off with dynamic IP is looking for an unreliable system. If your ISP can give you a static IP you'd be much better off.
  6. mear
    Aug 9, 2011
    16
    We have created a solution to the lack of FQDN support in 3cx Sip Proxy Gateway.
    While the uses of a Dynamic IP address is not recommended utilising a FQDN does assist with management of remote sites. If for example you need to fail-over to a backup ISP or you move office. This script will ensure that no changes need to be made to the remote sites. Also Great if you are running a Hosted version of 3cx. To get the Free script visit http://www.meartechnology.co.uk/TalkAbout/3cxProxyManagerFQDN.asp
  7. leejor
    11,277
    360
    A lot will depend on how often your dynamic IP actually changes. If your "device" (router/server/PC) is constantly powered, then there is a good chance that your IP may not change for months (baring any network maintenance by your provider). I've found that I have the same "dynamic" IP for six to eight months at a time. Of course, all providers are going to be different.
