SIP Register
Discussion in '3CX Phone System - General' started by jegumi, Mar 17, 2008.
  1. jegumi
    Mar 17, 2008
    Hi, I´m trying to use the gateway VoIP with a count of telefonica, but the register does not work. I take traces and I have seen that the software add the port behind all fields (domain, user...).
    I have tried to change the provider inbound and outbound parameters, but I think that this changes really don´t do anything on the call to register, and I don´t see any option to remove the port.
    To sum up, I have on the field register: telefonica.net:5060, and I need that this field looks like: telefonica.net.
    Anybody can help me?. Thanks in advance
    http://wirelessgroupies.blogspot.com
