SIP Registration Timer
Discussion in '3CX Phone System - General' started by v375844, Nov 19, 2008.
  1. v375844
    Nov 19, 2008
    When my phone resisters with 3CX, I get a 86400 lifetime (1 day). I would like to expand this, but can not alter the REGISTER from the phone. Is there a way in 3CX to respond to the REGISTER with a larger lifetime?
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    You need to make it 5 or 10 Minuets
  3. v375844
    Nov 19, 2008
    I can not find an option in 3CX to change it. It appears the default timer is 86400 and actually I'd like to make it 7 days!
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    you can only set it from your device or softphone
  5. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    what kind of phone are you using?
