SIP Retransmission Timers
Discussion in 'Windows' started by eggysplat, Oct 12, 2010.
  1. eggysplat
    Oct 12, 2010
    Just wondering if these could be implemented in the soft-phone offering (SIP T1, T2 & T4). We have a couple of customers who are bordering on 500ms round-trip time, and one or two that are in the region of ~950ms. The SIP re-transmission on calling is causing a number of problems when they make calls.
    As far as I know, no softphone implements customisable SIP retransmission timers. We recommend 3CXPhone and, have a pre-configured link, as it's by far the best soft-phone for Windows. However, I've tried 3CXPhone, X-Lite, Zoiper, SJPhone, ExpressTalk and, none of these allow you to change T1.
    I'm not sure how many other people would think this would be a welcome addition but, I think that for some problematic internet connections, it's a life-saver and would put 3CX phone even further ahead of the competition!!
    Kind Regards
    Daryl
    PS - I know it's community led, with no tech support but, if any developers do read this, please do consider it!! :)
    11,283
    360
    You might have better luck bring this up in....http://3cx.ideascale.com/
