SIP service not reg.
Discussion in '3CX Phone System - General' started by Anonymous, Nov 28, 2006.
  1. Anonymous
    Anonymous Guest
    I have beta 2 running pefectly wiht voipbuster
    buth now i have installed beta 3 and all the settings are correct
    and still the only thing 3cx is doing
    "15:13:34.769 LineImpl::update: Line: register line xxmynumberxxx "
    and line status stays off..
  2. Anonymous
    Anonymous Guest
    i think i see the problem now
    after going online wiht one of the internal ext with a softphone 3cx starts to reg the voip
    buth then this happends
    15:32:12.106 Registrar::eek:nFailure: Registration failure: <sip:MYusername@MYIP?????:38244> for sip:10000@MYIP????:38244
    15:32:00.639 LineImpl::update: Line: register line XmynumberX
    it seems that the voip service settings try to reg. with the 3cx instead of with sip.voipbuster.com
    because in the location where the sip.voipbuster.com suposed to be is my ip number of the 3cx server!?!!
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    310
    support info
    can you send us the support info file for this? So we can check?
  4. Anonymous
    Anonymous Guest
    yes
    where can i find this file?
