SIP/SIP Connection with Avaya
Discussion in '3CX Phone System - General' started by supplenta, May 8, 2017.
  1. supplenta
    Oct 3, 2012
    35
    I was wondering whether anybody has created a SIP trunk and connected with an Avaya phone system?
    We have a customer who would like to pass us calls from their Avaya and I know there is not a template that 3CX provides, so I'm just wondering if there is anything specific I would need to do?
    Also, whether there are any specific requirements on the Avaya end that they would need to be aware of?
    Thanks.
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Yes I've linked an Avaya ip office with 3cx .. works great. Simple sip trunk between the 2.
    supplenta likes this.
  3. supplenta
    Oct 3, 2012
    35
    Thanks Jason!
    Could you tell me what is required on the Avaya side? Just a simple SIP trunk? Anything specific?
    Thanks.
  4. Carlos Teca
    Apr 3, 2017
    9
    Jason, can you send me the configuration of Avaya or a print screen because I don't see the number in 3CX's extensions.
    Thank you so much
