SIP standard used
Discussion in '3CX Phone System - General' started by Anonymous, Oct 19, 2006.
  1. Anonymous
    Anonymous Guest
    Hi, I need more information about SIP standard used on your software. Could you help me ?
    Sip version ? 1.5 ? 2.0 ? RFC 3261 ?
    Rtp version ?
    Stun version ?
    Codec ? I see an old message about this : 'A current version supports only G.711 codecs (both a-Law and mu-Law) ' It's true ?
    Dtmf ?
    Best regards.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    312
    Standards supported
    Below are the standards we use
    SIP : v2.0
    RTP : v2.0
    STUN : RFC 3489
    Codec : G.711 (both)
    DTMF : None in beta2 (no IVR to make use of it) Beta 3 will have it
    Note that we are planning to support the GSM codec, which is royalty free and supported by several providers including NIkotel and Sipgate
