Solved SIP TLS and S-RTP with v15.5 SP3
Discussion in '3CX Phone System - General' started by poynter.net, Mar 2, 2018.
  1. poynter.net
    Aug 26, 2009
    36
    When will this be updated? https://www.3cx.com/docs/secure-sip/
    Can get SIP TLS to work, but not S-RTP. Does the phone need to provision against the .3cx domain rather than the internal IP?
    I understand SP4 will include provisioning out of the box, but possible to get release date for this?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @poynter.net
    Please note that we intent to provide out of the box SIP TLS provisioning in one of the upcoming service packs. As of right now we do not have ETA available but please keep an eye on our blog for updates.
    Regarding SRTP you need to enable it per extension through the management console under the Phone provisioning tab / 3CX client / RTP mode. Set it to "Only Secure".
    You must also enable it in the web interface of each phone.
    poynter.net likes this.
  3. poynter.net
    Aug 26, 2009
    36
    Thanks, after setting it at the extension first then the phone UI, its now working.
    I assume I could clone the template for now, adjust the settings and provision phones with that until the SP comes out?
  4. YiannisH_3CX
    May 10, 2016
    7,400
    535
