SIP Trunk authentication
Discussion in '3CX Phone System - General' started by mmmelvin, Mar 27, 2009.
  1. mmmelvin
    Mar 27, 2009
    I am trying to use a Generic SIP trunk setup and it requires me to specify authentication, but I thought SIP trunks worked by IP address. How can I turn this off so as to not send authentication information to my SIP trunk provider.
  2. ecwilson
    ecwilson New Member
    Jul 12, 2007
    118
    Hello mmmelvin
    Not all sip trunks work that way, it depends on who your provider
    is & how they run there network. What provider you are using???
    ecwilson
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,887
    190
    You can just specify a unique authentication ID , this is required by the system but will not be used for authentication. The password itself can be left blank.
  4. mmmelvin
    Mar 27, 2009
    I am using Bandwidth.com for a SIP trunk provider and I will try the next suggestion as well and let you know. Wondering if anyone else has used this provider?
  5. Nick Galea
    Jun 6, 2006
    1,887
    190
    You can not use that provider, you must use a supported one such as Nexvortex, Broadvox, Call centric and others....
  6. mmmelvin
    Mar 27, 2009
    I have chosen another provider. Thanks for your help.
