SIP Trunk calls receiving but no voice
Discussion in '3CX Phone System - General' started by kirankumar171, Apr 4, 2017.
  1. kirankumar171
    Apr 4, 2017
    5
    SIP Trunk calls out going and incoming but no voice
    firewall test also good please help me
    10,367
    228
    No voice, which direction? Both? If so it may be a Codec issue. Check the Activity logs for any error messages right after a call.
    Is this a new installation, or were the trunks working in the past? Which provider are you using?
  3. kirankumar171
    Apr 4, 2017
    5
    issue with both directions the trunks working fine in past
    Registration at 2022-Bridge has failed. Destination is not reachable, DNS error resolving FQDN, or service is not available.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,408
    282
    The error suggests that there is an issue with the trunk registration. Is it an IP based trunk or authentication based?
    Are you using an IP to register or an FQDN?
  5. kirankumar171
    Apr 4, 2017
    5
    Hi it is authentication based
    yes I'm using IP
  6. kirankumar171
    Apr 4, 2017
    5
    ware I have to register FQDN
  7. YiannisH_3CX
    May 10, 2016
    4,408
    282
    Calls between extensions have audio? I would start by disabling anything that may block traffic to and from the PBX.
    Also you can try a free test provider to see if audio is ok with a different provider. If it works then you need to contact your provider.
  8. kirankumar171
    Apr 4, 2017
    5
    Calls between extensions audio is good only the issue with SIP trunk
