sip-trunk from my ISP
Discussion in '3CX Phone System - General' started by klimdos, Oct 8, 2013.
  1. klimdos
    Sep 9, 2013
    6
    I have a problem with connection sip-trunk from my ISP.
    outgoing messages Calls are successful, and there is no Incoming.
    log 3cx:
    Code:
    08-окт-2013 14:49:13.544	[CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    			Invite-UNK Recv Req INVITE from 192.168.59.3:5060 tid=681d0206 Call-ID=51fbdd796142f485406373762137227c@192.168.59.3:
    			INVITE sip:7031394@192.168.95.2 SIP/2.0
    			Via: SIP/2.0/UDP 192.168.59.3:5060;branch=z9hG4bK681d0206;rport=5060
    			Max-Forwards: 70
    			Contact: <sip:8127021262@192.168.59.3>
    			To: <sip:7031394@192.168.95.2>
    			From: "Elektronmash ZAO"<sip:8127021262@192.168.59.3>;tag=as03c6f31a
    			Call-ID: 51fbdd796142f485406373762137227c@192.168.59.3
    			CSeq: 102 INVITE
    			Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
    			Content-Type: application/sdp
    			Date: Tue, 08 Oct 2013 10:49:14 GMT
    			Supported: replaces
    			User-Agent: CCS01
    			Content-Length: 184
    			v=0
    			o=root 24780 24780 IN IP4 192.168.59.3
    			s=session
    			c=IN IP4 192.168.59.3
    			t=0 0
    			m=audio 16292 RTP/AVP 8
    			a=rtpmap:8 PCMA/8000
    			a=silenceSupp:off - - - -
    			a=ptime:20
    			a=sendrecv
    and
    Code:
    08-окт-2013 14:19:22.643	[CM102001]: Authentication failed for AuthFail Recv Req INVITE from 192.168.59.3:5060 tid=04254c87 Call-ID=31007c2e2f02dd59542ca0be0b6a057f@192.168.59.3:
    			Via: SIP/2.0/UDP 192.168.59.3:5060;branch=z9hG4bK04254c87;rport=5060
    			Max-Forwards: 70
    			From: "Elektronmash ZAO"<sip:8127021262@192.168.59.3>;tag=as537c43f4
    			Call-ID: 31007c2e2f02dd59542ca0be0b6a057f@192.168.59.3
    			CSeq: 103 INVITE
    			Date: Tue, 08 Oct 2013 10:19:23 GMT
    			Proxy-Authorization: Digest username="1981",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:7031394@192.168.95.2",nonce="414d535c08646d2a10:d508a41056a63a1536f336e2fcdf66f4",response="450d12b542ef96df869d7e01b6807cc3"
    			Supported: replaces
    			User-Agent: CCS01
    			Content-Length: 184
    			v=0
    			o=root 24780 24781 IN IP4 192.168.59.3
    			s=session
    			t=0 0
    			m=audio 11656 RTP/AVP 8
    			a=ptime:20
    			a=sendrecv
    			; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    log from a server provider.
    Code:
    U 2013/10/07 11:30:42.722724 192.168.59.3:5060 -> 192.168.95.2:5060
    INVITE sip:7031394@192.168.95.2 SIP/2.0.
    Via: SIP/2.0/UDP 192.168.59.3:5060;branch=z9hG4bK0dea3da8;rport.
    From: "Elektronmash ZAO" <sip:8127021262@192.168.59.3>;tag=as42c0a097.
    To: <sip:7031394@192.168.95.2>.
    Contact: <sip:8127021262@192.168.59.3>.
    Call-ID: 4201134d417646007e1d2c9e45693988@192.168.59.3.
    CSeq: 102 INVITE.
    User-Agent: CCS01.
    Max-Forwards: 70.
    Date: Mon, 07 Oct 2013 07:30:42 GMT.
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY.
    Supported: replaces.
    Content-Type: application/sdp.
    Content-Length: 184.
    v=0.
    o=root 24780 24780 IN IP4 192.168.59.3.
    s=session.
    c=IN IP4 192.168.59.3.
    t=0 0.
    m=audio 11998 RTP/AVP 8.
    a=rtpmap:8 PCMA/8000.
    a=silenceSupp:off - - - -.
    a=ptime:20.
    a=sendrecv.
    U 2013/10/07 11:30:42.773461 192.168.95.2:5060 -> 192.168.59.3:5060
    SIP/2.0 407 Proxy Authentication Required.
    Via: SIP/2.0/UDP 192.168.59.3:5060;branch=z9hG4bK0dea3da8;rport=5060.
    Proxy-Authenticate: Digest
    nonce="414d535c0862f42360:453457cf60985d00dae043f8ac994949",algorithm=MD5,realm="3CXPhoneSystem".
    To: <sip:7031394@192.168.95.2>;tag=2465f87f.
    From: "Elektronmash ZAO"<sip:8127021262@192.168.59.3>;tag=as42c0a097.
    CSeq: 102 INVITE.
    User-Agent: 3CXPhoneSystem 12.0.32127.322 (32093).
    Content-Length: 0.
    U 2013/10/07 11:30:42.774220 192.168.59.3:5060 -> 192.168.95.2:5060
    ACK sip:7031394@192.168.95.2 SIP/2.0.
    CSeq: 102 ACK.
    User-Agent: CCS01.
    Max-Forwards: 70.
    Content-Length: 0.
    U 2013/10/07 11:30:42.774315 192.168.59.3:5060 -> 192.168.95.2:5060
    Via: SIP/2.0/UDP 192.168.59.3:5060;branch=z9hG4bK4aac6050;rport.
    CSeq: 103 INVITE.
    User-Agent: CCS01.
    Max-Forwards: 70.
    Proxy-Authorization: Digest username="1981", realm="3CXPhoneSystem",
    algorithm=MD5, uri="sip:7031394@192.168.95.2",
    response="cd6bdf87abc36360f93ecf3665bda206".
    v=0.
    o=root 24780 24781 IN IP4 192.168.59.3.
    s=session.
    t=0 0.
    a=ptime:20.
    a=sendrecv.
    U 2013/10/07 11:30:42.878105 192.168.95.2:5060 -> 192.168.59.3:5060
    SIP/2.0 404 User unknown..
    Via: SIP/2.0/UDP 192.168.59.3:5060;branch=z9hG4bK4aac6050;rport=5060.
    To: <sip:7031394@192.168.95.2>;tag=3d534227.
    CSeq: 103 INVITE.
    Content-Length: 0.
    U 2013/10/07 11:30:42.878260 192.168.59.3:5060 -> 192.168.95.2:5060
    CSeq: 103 ACK.
    User-Agent: CCS01.
    Max-Forwards: 70.
    Content-Length: 0.
    support provider can not help me - they say that have never set up 3cx
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    check under VoIP provider--->Source ID---> and assure you have added and selected the DIDs to the pbx. You may want to post a wire shark log xxx out ips etc.... as there isnt much information to go on here.
