SIP Trunk issue
Discussion in '3CX Phone System - General' started by Alenlin, Dec 14, 2017.
  1. Alenlin
    Nov 1, 2017
    5
    I am a newer to 3CX.
    Now I am learning how to configure the SIP Trunk.
    Question 1:
    Why does dashboard indicates 4 SIP Trunks but actually I only configured 3.
    The pictures as follows:
    Question 2:
    Why do we have to configure Numbers of Physical PSTN Ports On Device.
    In my view, I can just specify the number of SIM Call and that is enough.
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
    Hello @Alenlin
    For your first question, regarding the SIP trunks, please note that Gateways and Bridges are considered as Trunks as well from the PBX. So you must take into account these as well.
    Regarding your 2nd question, it seems from your screenshot, that you are trying to configure a Gateway and not a SIP Trunk. A VoIP gateway (or PSTN Gateway) is a device which converts telephony traffic into IP for transmission over a data network.
  3. Alenlin
    Nov 1, 2017
    5
    Thank u for answering my questions.
    Regarding my 2nd question, why do we have to specify the number of ports on the device?
  4. leejor
    10,781
    287
    There are various types of gateways, from different manufacturers, and they can handle calls from the PBX in a number of ways. The options may be necessary to accommodate this.
  5. Alenlin
    Nov 1, 2017
    5
    It's very nice of u answering my question.
    I still don't know why we must to specify the number of physical ports?
    Or in other words, if we don't specify that,what will happen?
  6. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,350
    78
    You must understand that these options exist in the interface with the supported GWs in mind. They are used mainly in the background to generate things for the provisioning files. If you are going the Generic GW route, then these probably don't apply for you as most of the config will have to be done manually.
