Solved SIP Trunk Mismatch
Discussion in '3CX Phone System - General' started by akjon RooSho, Dec 7, 2018 at 5:22 PM.
Tags:
  1. akjon RooSho
    Jun 20, 2018
    5
    I've got some mismatch with SIP trunks in my 3CX. I've configured local IPTSP numbers as Generic SIP trunks.
    This is my dashboard
    But I've configured only 4 SIP trunks. But the dashboard says 5 out of 5 are online.
    I'm not sure how did the 5th came. But I don't see the 5th one even into SIP trunks.
    Can anyone explain?
    Thanks in advance
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,590
    238
    Do you have a Bridge setup?
  3. akjon RooSho
    Jun 20, 2018
    5
    No, Nothing except 4 SIP trunks and 7 extensions
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Hello @akjon RooSho
    What PBX version are you running? You can see the exact build number on the Dashboard, under the Information column next to the licence version. For example 15.5.15502.6.
  5. TBWD
    Feb 28, 2018
    41
    9
    I have the same issue, I just thought it was because I am using V16 Alpha.
  6. YiannisH_3CX
    May 10, 2016
    7,358
    535
    In the V16 alpha there is a bridge to the Webmeeting service that counts as a trunk so that is normal.
  7. TBWD
    Feb 28, 2018
    41
    9
    Ok, that works for me. Did not know
  8. akjon RooSho
    Jun 20, 2018
    5
    My version is 16.0.0.
    According to,
    I guess my fifth trunk is webmeeting service.
    Thanks a lot for your help.
    Regards
  9. YiannisH_3CX
    May 10, 2016
    7,358
    535
    Yes, that is correct. Glad i could assist.
