SIP Trunk not registered
Discussion in '3CX Phone System - General' started by jmetcalfe, Jul 26, 2010.
  1. jmetcalfe
    Jul 26, 2010
    5
    I have a SIP Trunk from Entanet (Entacall) which I have set up on the 3CX PABX and it tells me in the Activity log that the registration was successfull and the VoIP provider can see that a 3CX PABX is registered at there end, but the "Port/Trunk status sais it it "Not Registered".
    Can someone point me in the right direction.
    Justin
    10,357
    224
    Do you have any problems placing or receiving calls? If not, then it may just be a status issue of some sort.
  3. jmetcalfe
    Jul 26, 2010
    5
    I reloaded the system yesterday, and now the trunk is showing registerd on the 3CX system, but not on the ISPs system. I am now receiving calls from the utside world, so it must be registered, but I can't make outgoing calls, he cause being "Server Internal Error".
    I have also notice that the "Queue Manager Service" will not start for some reason I can't fathom. This may be the cause of my problems.
    Justin
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Server error can be a multitude of things,check if the voip provider are recieving the call, also i n regards to the que manager, pleas emake sure you are running the latest relase of the 3CX version 9, also if you have any Ques please delete them and start the service before starting to create them again.
  5. jmetcalfe
    Jul 26, 2010
    5
    Thanks, I'll give that a try. I don't think I have any queues. Unless an outbound rule is a queue, I don't think I have any set up.
    Justin
  6. leejor
    10,357
    224
    What does the 3CX log look like when it first starts and does a registration attempt with the provider?
  7. jmetcalfe
    Jul 26, 2010
    5
    The 3CX Sais it is registered with the provide, but the provider system says it's not. I am in contact with the supplier, so I'll get it sorted with them and let you know.
