- Joined
- Aug 3, 2017
- Messages
- 24
- Reaction score
- 2
I am using ANVEO Direct as outbound provider. For security and authentication, they use a combination of origin IP and a 5 character prepended onto the called number. Their instructions are:
Send calls from authorized IPs to:
[PREFIX][email protected]
where [PREFIX] is your custom configured prefix for the trunk and PHONENUMBER is destination phone number with country code.
I was able to achieve this by prepending the prefix at the outbound rules. Calls worked correctly. Problem is that now all calls are logged including the "secret" prefix and even show up in the 3CX client's call history.
I couldnt find a way to prepend at the trunk level as is possible on PiaF.
I am guessing this could be done at the Trunks, Outbound Parameters, SIP Fields
maybe by using the CUSTOM option on the TO field.
If indeed this is possible, is there a way to incorporate variables in the custom field? so that I can prepend the ANVEO security prefix to the "CalledNum"?
thank you,
gulib
thank you,
gulib
