SIP Trunk Provider Modification
Discussion in '3CX Phone System - General' started by architechture, Dec 7, 2018 at 7:42 PM.
  1. architechture
    Apr 3, 2013
    8
    What modification to a SIP trunk will cause it to show as:
    "You are using Unsupported SIP trunk providers which may cause issues."
    I used one from the dropdown and after modification it shows the error above on the dashboard.
    Thanks,
  2. architechture
    Apr 3, 2013
    8
    So it looks like this problem was caused not by a simple modification but by exporting and importing. I'll test further.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Hello @architechture
    Please note that if you import a providers template the system will recognise that as a non supported provider and you will get the unsupported warning.
    I would recommend using the 3CX provided template when adding trunks.
  4. TBWD
    Feb 28, 2018
    41
    9
    On a similar note, we have just become a supported SIP trunk provider, is there an easy way to change from the non-supported, to our supported template, or do I just have to create a new trunk?
  5. YiannisH_3CX
    May 10, 2016
    7,358
    535
    You will need to create a trunk to be able to use the new template. Also when a template update is released the changes are not auto applied to existing trunks as we do not want to override any changes the user might have done to the trunk .
  6. TBWD
    Feb 28, 2018
    41
    9
    Thanks for the update, that is as I thought and have been doing it that way.
    YiannisH_3CX likes this.
  7. architechture
    Apr 3, 2013
    8
    So, if I export a verified provider template and import it in order to change just the Main Trunk number, it now becomes invalid? Hmmm....
  8. YiannisH_3CX
    May 10, 2016
    7,358
    535
    The phone system is not aware of what is imported when you import a template and is not aware what changes were made so the trunk will be flagged as a non supported trunk.
