SIP Trunk redundant outbound proxy
Discussion in '3CX Phone System - General' started by PhatPanda, Jan 5, 2018.
  1. PhatPanda
    Aug 26, 2015
    58
    We used a supported SIP trunk provider, VOIP Innovations. They had an outage yesterday on their main outbound proxy IP, however they provide multiple redundant IP addresses, which did not experience the issue. Can 3cx or anyone suggest how to take advantage of these redundant outbound IPs, if possible? No place in the provided template to utilize additional outbound IPs. Can this be done by creating additional outbound calling rules? I believe the system was seeing 503 responses during the downtime for termination traffic.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    Can you create an SIP trunk with the new outbound IP address.
    Under Outbound rules, modify the rule and and add the new SIP trunk to route2
  3. PhatPanda
    Aug 26, 2015
    58
    Actually I looked at the list of supported SIP Trunks, and VoipInnovations is no longer on the list ...??
  4. PhatPanda
    Aug 26, 2015
    58
    I see, will give that a shot
  5. PhatPanda
    Aug 26, 2015
    58
    I can't create another outbound path since I can't select a template for Voipinnovations, it doesn't show up under any country or worldwide.....
  6. Saqqara
    Mar 12, 2014
    1,252
    203
    Only supported providers will have templates
    Can you not use Generic - Sip Trunk and copy the settings from your current sip trunk,
    Maybe worth a call to Voipinnovations to configure it.
  7. PhatPanda
    Aug 26, 2015
    58
    That's what VI suggested, they said they are working on becoming certified again at this time. Thanks-
