SIP Trunk
Discussion in '3CX Phone System - General' started by sippy, Feb 12, 2011.
  1. sippy
    Feb 12, 2011
    I have a sip trunk which authorizes me by my IP. When i am adding my voip provider, I am selecting generic sip trunk form the list. IN the manual it says that if you select 'generic sip trunk' that 'authentication id' and 'authentication password' will be grayed out because they are not applicable. However, they are not gray and I am getting a pop up message requiring me to enter this data. Any suggestion as to how to get around this? Thank you.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, just enter anything in the boxes for authentication id' and 'authentication password
    This should be ignored anyway by 3CX and the VoIP Provider.
    let us know if this works?
