SIP Trunks
Discussion in '3CX Phone System - General' started by gschwab, May 18, 2012.
  1. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    If you had to buy SIP trunks today for a small business (currently have 3CX, 4 PSTN Lines to a gateway) and price is NOT a major deciding factor but the following are, who would you choose?
    Reliability. uptime is huge to me, I would not be happy if the system were down for any length of time.
    Voice quality
    Must be supported by 3CX
    Good support staff.
    thanks for any input
    George
  2. paul.hadley
    paul.hadley New Member
    Aug 24, 2010
    122
    Where are you based ?
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    I can only speak of 1 here in the US - NexVortex. Sound seems good. No downtime. Easy setup. But we have only been on about 20 days.
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    I second nexVortex, have used them for a couple of years. I can also say that Broadvox was good. Kerry garrison at Vitality may also be a good choice.
    Whatever you do, do yourself a favor and use a supported provider. it will eliminate most, if not all, of the setup issues.
  5. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Florida / USA
  6. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I would have to say Broadvox, I use them for my office as well as all of my clients who go with SIP. Service is great, easy to provision, 3cx approved produt. I wouldn't use another provider
  7. active5
    Jun 28, 2011
    72
    I would talk to Vitelity, it looks like they wholesale to others listed as tested SIP providers. I'm trying them out soon. I have used Broadvox, Voicepulse, Callcentric and XeloQ (international)
    Vitelity has a network access point in southern Florida.
