SIP URL to Call Assistance not working
Discussion in '3CX Phone System - General' started by seetarc, Aug 18, 2010.
  1. seetarc
    Aug 29, 2008
    45
    I have notices that SIP URL to Digital Receptionist does not work that is;
    I have my Digital Receptionist as 800
    PBX Server as pbx.mydomain.com
    Then i configured my DID to send calls to 800@pbx.mydomain.com
    This configuration does not work in ver8 and ver9 but worked in ver7 downwards. I was hoping ver 9 will rectify this.
    However, as a work around. if i create a dummy ext 100 and forward all calls to ext 100 to Digital Receptionist (800) and when I call my DID # forwarded to 100@pbx.mydomain.com then Digital Receptionist picks up.
    Any idea ?
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Why are you not using inbound rules to do this?
    Set an inbound rule for the did to forward to the digital assistant on 800. Thats what the inbound rules are for.
  3. seetarc
    Aug 29, 2008
    45
    Inbound rule will not work in this case as i don't know the number that calls could be calling form. Inbound rule is for numbers you know and you want to route accordingly. Thanks
  4. abc123
    Nov 9, 2009
    712
    No it isnt :)
    Inbound rule is for DIDs. it looks at the sip TO field not FROM field. Trust me i have 29 set up.
    you can use either the DID/DDI Name, or the DID/DDI number/mask (i tend to use the latter). Put in the number that the users will CALL (eg 555-555-5555) and chose the port it will come in on (ie your voip provider)
    Then configure office hours to go to Connect to Digital Assistant. Optionally choose something for out of office hours.
  5. seetarc
    Aug 29, 2008
    45
    thanks abc123, Am not using a VoIP Provider. That is, i did not connect via a username/password. I am sending calls using sip url from my DID Provider
  6. abc123
    Nov 9, 2009
    712
    ahh my mistake - I didnt realize that.
    I dont believe you can use IVR urls (ie for digital assistants) so you may have to stick with your dummy url.
    The only other thing I can suggest is to put wireshark on the pbx and capture the trace and see what we can find. You can post it here or email it to me.
