sip2sip.info configuration
Discussion in 'Windows' started by tomfmason, Aug 11, 2010.
  1. tomfmason
    Aug 11, 2010
    I have everything setup correctly in the settings asfaik .
    extension and id are the same
    password is correct
    out of office is selected and filled with sip2sip.info
    advanced settings:
    local port - any is checked
    pbx voicemail is blank
    rtp ports 50000:50012
    stun: empty
    everything else is left at defaults
    log:
    Translation file OK
    Attempting to connect sip2sip.info
    Required STUN name is empty, using default
    Phone got as local port 3929
    Integration with 3CX Call Assistant is OFF
    RTP engine OK
    SIP engine OK
    Sound mic device OK [{BD6DD71B-3DEB-11D1-B171-00C04FC20000}]
    Sound ring device OK []
    Sound play device OK [{BD6DD71A-3DEB-11D1-B171-00C04FC20000}]
    Phone is sending STUN request
    Phone connection failed, server not responding
    I am able to connect with xlite without a problem. Any suggestions would be great
    Thanks,
    Tom
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,416
    61
    Hi Tom
    Stun should not be empty, please try one of following
    http://www.3cx.com/forums/stun-servers-12201.html
    Hope it helps
    vali
