Sipdroid
Discussion in '3CX Phone System - General' started by mylove4life, Mar 31, 2010.
  1. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Hi all, any one get SIPDroid to work yet for outgoing calls? Works fine for incomming.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    SIPDroid has a numerous versions. What is the version you are talking about?
  3. mylove4life
    Jan 7, 2010
    165
    Version 1.4.4 beta for the Moto Droid
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    Can you provide additional information?
  5. mylove4life
    Jan 7, 2010
    165
    Not really. I am willing to use something else. Is there one that works 100% on the Droid?
  6. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    312
    You can use SIPagent...
  7. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,582
    115
    SipAgent works pretty well with 3CX.
    There's just 1 bug at the moment where you cannot put calls on hold. Other than that it works pretty flawlessly.
    Be sure to go to the Extension's settings > Other > PBX Delivers Audio Tick that setting to avoid any problems.
    Though i've tested SipDroid as well, i was able to make calls, though i did not give it much attention as i was testing SipAgent.
    But i'm going to try SIPDroid out as well and test it thoroughly with 3CX and see how it goes.
  8. tjericson
    Jan 29, 2009
    25
    sipagent seems to be working well for me except for one issue, when i get an incoming call while on vibrate i get no alert but when the ringer is on, it works fine, anyone else have the same issue?
  9. LeonidasG
    Nov 19, 2008
    1,582
    115
    That's something i've actually never noticed honestly.
    It could be an issue with the software but it could just be an android issue.
    In any case i'll be checking it out when possible.
  10. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    I also love sipagent and have used it since beta.
    However as we use skype and others i can also recommend Fring. The nice thing about Fring is you can choose which system to use when you dial out (e.g. Cell, skype, 3cx etc).
  11. Destonomos
    Apr 30, 2010
    18
    I've been using Fring on my iphone and it seems to work flawlessly with multiple pbx's. I'm pretty sure it has a client for android as they have the nexus 1 as a rotating image on their site. http://www.fring.com
