Sipgate and CallerID
Discussion in '3CX Phone System - General' started by Pentangle, Jan 4, 2008.
  1. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    So I have a 3cx system at work, and a 3cx system at home. They both have a Sipgate VoIP line and everything works fine....
    ...except the Caller ID is reported as being the Sipgate SIP ID rather than the caller ID despite both Sipgate systems being set to deliver caller ID and both 3cx systems set to send caller ID.
    Any ideas?
  2. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    I am also using SIPGate and the lines show the correct number not the ID
  3. silentfun
    silentfun Member
    Dec 11, 2006
    364
    also using sipgate but in v3 i have set it to anonymus to not send the number and it have worked not in v5 - until now i have not found where to do this now.
    atm he show the voip number to the caller and the caller numbers on y phones.
    Andy
  4. aryagohar
    Jan 20, 2008
    hi there
    i'd tried serveral ways, but when my voip gateway send the CallerID instead of the registration no.
    the call rejected by 3cx.
    I'm using v5 right now. but I have the same problem with CID.
    i tried AXON , with same configuration , it send teh callerID. i think this problem is a native bug of 3CX.
