sipgate diversion header
mixig
i am testing diversion header with sipgate sip trunk which it is 3cx supported voip provider but it is not working, can someone who has also sip trunk from sipgate test this feature?
Does the VOIP Provider support diversion?
I tested this provider some time ago and diversion header did not work. The only one in the UK that I have found that works is Voipfone.
Kind regards
Richard
Hi guys, well i didn t check with provider, i assumed as 3cx supported provider it support diversion header, but it seems that they dont support that features. i will contact them to be sure...
Get 3CX - Absolutely Free!
3CX
