Sipgate: Incoming calls work but no sound
Discussion in '3CX Phone System - General' started by lrebibo, Aug 27, 2007.
  1. lrebibo
    Aug 27, 2007
    Hi all,
    I just registered Sipgate as a VOIP provider. When I call the telephone number -attributed to sipgate, it rings, but I can't hear anything neither on the phone from which I call from, nor on the one that I call to.
    Surprisingly, it works fine for the other VOIP providers (voipcheap...) that I registered through 3CX.
    It also works fine when I configure Sipgate directly into my PAP2 (=> not into 3CX).
    Many thanks for your help
  2. gbarnes
    Aug 3, 2007
    83
    Equipment
    What equipment are you using? Could you post a log.
    In sipgate settings, under edit voip provider, do you have these settings:
    Registrar/Proxy Hostname or IP : sipgate.co.uk
    Stun : Blank
    Proxy : Blank
    Other options : PBX delivers audio
    I have sipgate set up like that here so it should work. Ports I use are 8000 - 80xx RTP, 5060 sip.
    Graeme.
