SIPGATE ISSUE
Discussion in '3CX Phone System - General' started by amygoda, Dec 24, 2010.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    any 1 can help to connect to sipgate
    10,781
    286
    What are the issues that you are having?
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    It can not register at all
    and when I tried soft phone it register but do not call or receive calls
  4. leejor
    10,781
    286
    It could be a number of things. Posting the 3CX log showing the registration failure might be a place to start. Have you run the 3CX firewall checker on your network? If the soft phone isn't able to place calls then it may very well be your router or a firewall issue.
  5. amygoda
    amygoda Member
    Sep 18, 2006
    436
    only sipgate USA does not work
    I have sipgate UK works fine
    also I tried other voip providers and most of them works fine
  6. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Out of curiosity I created an account, got a CA number and it registered on the fly, no issue at all. Voice quality is very bad however!
  7. amygoda
    amygoda Member
    Sep 18, 2006
    436
    I found it
    sipgate usa does not support non usa ip
