Sipgate outgoing call making problems - help please & other.
Discussion in '3CX Phone System - General' started by h2009, Mar 16, 2008.
  1. h2009
    h2009 Member
    Mar 15, 2008
    447
    Hi there,
    Im just testing out VOIP now, but i've come into a problem.
    I can dial in to my Sipgate accounting using my telephone number given to me, but i cant seem to call out. I get a dial tone, but i just the messaged back to saying destination unknown.
    Here is the log:
    14:08:19.812 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 64.69.76.23 has timed out; used Transport: 192.168.0.200:5060
    14:08:16.750 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 64.69.76.23 has timed out; used Transport: 192.168.0.200:5060
    14:08:15.015 Call::Terminate [CM503008]: Call(10): Call is terminated
    14:08:15.000 Call::RouteFailed [CM503014]: Call(10): Attempt to reach [sip:10000@192.168.0.200:5060] failed. Reason: Not Found
    14:08:15.000 CallCtrl::eek:nSelectRouteReq [CM503013]: Call(10): No known route to target: [sip:10000@192.168.0.200:5060]
    14:08:14.984 CallCtrl::eek:nIncomingCall [CM503001]: Call(10): Incoming call from Ext.100 to [sip:10000@192.168.0.200:5060]
    14:08:13.671 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 64.69.76.23 has timed out; used Transport: 192.168.0.200:5060
    14:08:12.937 ExtnCfg::updateContact [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:100@192.168.0.195:5070;rinstance=ae7a10222974903d/100]
    14:08:12.687 ExtnCfg::updateContact [CM504002]: Ext.100: a contact is unregistered. Contact(s): []
    Incoming call log
    14:08:46.328 Call::Terminate [CM503008]: Call(11): Call is terminated
    14:08:46.328 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:100
    14:08:44.296 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 64.69.76.23 has timed out; used Transport: 192.168.0.200:5060
    14:08:43.031 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(11): Calling: Ext:100@[Dev:sip:100@192.168.0.195:5070;rinstance=ae7a10222974903d]
    14:08:43.031 Line::printEndpointInfo [CM505003]: Provider:[Sipgate] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.0.200:5060]
    14:08:43.031 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:100
    Also as you can see i keep getting the STUN request coming up, what do they mean? How can i fix the problem?
    Thans
  2. h2009
    h2009 Member
    Mar 15, 2008
    447
    Anyone?
    I've got another problem now, and that is sipgate line is not registering any more.
    I dont know whats caused it, but the firewall test in 3CX all pass. Im getting the stun server timed out messages.
    Does the stun server need to work to allow registration to sipgate?
  3. h2009
    h2009 Member
    Mar 15, 2008
    447
    Ok i've fixed part of the problem again.
    Now call incoming work fine.
    But outbound calls don't, here is the log (although it looks like 999 call works? :
    01:20:15.609 Call::Terminate [CM503008]: Call(5): Call is terminated
    01:20:09.656 CallLeg::eek:nConfirmed Session 25 of leg C:5.1 is confirmed
    01:20:09.562 CallCtrl::eek:nLegConnected [CM503007]: Call(5): Device joined: sip:101@192.168.0.196:5060
    01:20:09.562 MediaServerReporting::SetRemoteParty [MS210003] C:5.1:Answer provided. Connection(transcoding mode):192.168.0.200:7008(7009)
    01:20:08.828 CallCtrl::eek:nLegConnected [CM503007]: Call(5): Device joined: sip:
    01:20:08.812 MediaServerReporting::SetRemoteParty [MS210000] C:5.1:Offer received. RTP connection: 192.168.0.200:8000(8001)
    01:20:08.812 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(5): Calling: IVR:999@[Dev]
    01:20:08.812 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:999@192.168.0.200]
    01:20:08.812 CallLeg::setRemoteSdp Remote SDP is set for legC:5.1
    01:20:08.812 Extension::printEndpointInfo [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NCH Swift Sound Express Talk 3.04] Transport: [sip:192.168.0.200:5060]
    01:20:08.796 CallCtrl::eek:nIncomingCall [CM503001]: Call(5): Incoming call from Ext.101 to [sip:999@192.168.0.200]
    01:20:08.796 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:999@192.168.0.200 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.196:5060;rport=5060;branch=z9hG4bK32255
    Max-Forwards: 20
    Contact: [sip:101@192.168.0.196:5060]
    To: [sip:999@192.168.0.200]
    Call-ID: 1205715494-255-Layth%20Hamza%E2%80%99s%20MacBook%20Pro@192.168.0.200
    CSeq: 870 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, INFO, REFER, NOTIFY
    Proxy-Authorization: Digest username="101",realm="3CXPhoneSystem",nonce="12850190408:f60b9588f710949151b43c9852cd8a4f",uri="sip:999@192.168.0.200",response="d057146177e5fbc1e33ffc5662448f26",opaque="",algorithm=MD5
    Supported: replaces
    User-Agent: NCH Swift Sound Express Talk 3.04
    Content-Length: 0
    01:19:59.468 Call::Terminate [CM503008]: Call(4): Call is terminated
    01:19:59.453 MediaServerReporting::SetRemoteParty [MS210000] C:4.1:Offer received. RTP connection: 192.168.0.200:8000(8001)
    01:19:59.453 Call::RouteFailed [CM503014]: Call(4): Attempt to reach [sip:911@192.168.0.200] failed. Reason: Not Found
    01:19:59.453 CallCtrl::eek:nSelectRouteReq [CM503013]: Call(4): No known route to target: [sip:911@192.168.0.200]
    01:19:59.453 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:911@192.168.0.200]
    01:19:59.437 CallLeg::setRemoteSdp Remote SDP is set for legC:4.1
    01:19:59.437 Extension::printEndpointInfo [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NCH Swift Sound Express Talk 3.04] Transport: [sip:192.168.0.200:5060]
    01:19:59.437 CallCtrl::eek:nIncomingCall [CM503001]: Call(4): Incoming call from Ext.101 to [sip:911@192.168.0.200]
    01:19:59.437 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:911@192.168.0.200 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.196:5060;rport=5060;branch=z9hG4bK30255
    Max-Forwards: 20
    To: [sip:911@192.168.0.200]
    Call-ID: 1205715493-255-Layth%20Hamza%E2%80%99s%20MacBook%20Pro@192.168.0.200
    CSeq: 439 INVITE
    Proxy-Authorization: Digest username="101",realm="3CXPhoneSystem",nonce="12850190399:fa113651f064e973fcdb4ed2d9f98dbf",uri="sip:911@192.168.0.200",response="969eac538d7870416a85f04f2abfc1d3",opaque="",algorithm=MD5
    Supported: replaces
    Content-Length: 0
    01:19:48.000 Call::Terminate [CM503008]: Call(3): Call is terminated
    01:19:47.984 MediaServerReporting::SetRemoteParty [MS210000] C:3.1:Offer received. RTP connection: 192.168.0.200:8000(8001)
    01:19:47.984 Call::RouteFailed [CM503014]: Call(3): Attempt to reach [sip:01273818365@192.168.0.200] failed. Reason: Not Found
    01:19:47.984 CallCtrl::eek:nSelectRouteReq [CM503013]: Call(3): No known route to target: [sip:01273818365@192.168.0.200]
    01:19:47.984 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:01273818365@192.168.0.200]
    01:19:47.984 CallLeg::setRemoteSdp Remote SDP is set for legC:3.1
    01:19:47.984 Extension::printEndpointInfo [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NCH Swift Sound Express Talk 3.04] Transport: [sip:192.168.0.200:5060]
    01:19:47.968 CallCtrl::eek:nIncomingCall [CM503001]: Call(3): Incoming call from Ext.101 to [sip:01273818365@192.168.0.200]
    01:19:47.968 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:01273818365@192.168.0.200 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.196:5060;rport=5060;branch=z9hG4bK28255
    Max-Forwards: 20
    To: [sip:01273818365@192.168.0.200]
    Call-ID: 1205715492-255-Layth%20Hamza%E2%80%99s%20MacBook%20Pro@192.168.0.200
    CSeq: 186 INVITE
    Proxy-Authorization: Digest username="101",realm="3CXPhoneSystem",nonce="12850190387:f103931a162b4e2e3e056c3eef207ade",uri="sip:01273818365@192.168.0.200",response="7c3bd3bdd39c31c63f2d3aaa723f602e",opaque="",algorithm=MD5
    Supported: replaces
    Content-Length: 0
    01:19:38.156 Call::Terminate [CM503008]: Call(2): Call is terminated
    01:19:38.140 Call::Terminate [CM503008]: Call(2): Call is terminated
    01:19:35.500 CallLeg::eek:nConfirmed Session 15 of leg C:2.1 is confirmed
    01:19:35.406 CallCtrl::eek:nLegConnected [CM503007]: Call(2): Device joined: sip:101@192.168.0.196:5060
    01:19:35.406 MediaServerReporting::SetRemoteParty [MS210003] C:2.1:Answer provided. Connection(transcoding mode):192.168.0.200:7002(7003)
    01:19:34.703 CallCtrl::eek:nLegConnected [CM503007]: Call(2): Device joined: sip:
    01:19:34.671 MediaServerReporting::SetRemoteParty [MS210000] C:2.1:Offer received. RTP connection: 192.168.0.200:8000(8001)
    01:19:34.671 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(2): Calling: IVR:999@[Dev]
    01:19:34.671 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:999@192.168.0.200]
    01:19:34.671 CallLeg::setRemoteSdp Remote SDP is set for legC:2.1
    01:19:34.671 Extension::printEndpointInfo [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NCH Swift Sound Express Talk 3.04] Transport: [sip:192.168.0.200:5060]
    01:19:34.656 CallCtrl::eek:nIncomingCall [CM503001]: Call(2): Incoming call from Ext.101 to [sip:999@192.168.0.200]
    01:19:34.656 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 192.168.0.196:5060;rport=5060;branch=z9hG4bK24255
    Max-Forwards: 20
    Call-ID: 1205715491-255-Layth%20Hamza%E2%80%99s%20MacBook%20Pro@192.168.0.200
    CSeq: 471 INVITE
    Proxy-Authorization: Digest username="101",realm="3CXPhoneSystem",nonce="12850190374:1df5fbcbc4dccd507ec4d107f4ba9c85",uri="sip:999@192.168.0.200",response="657e60bfa2d4f6662e5b064a58b63f4d",opaque="",algorithm=MD5
    Supported: replaces
    Content-Length: 0
    01:19:22.515 Call::Terminate [CM503008]: Call(1): Call is terminated
    01:19:22.500 Call::RouteFailed [CM503014]: Call(1): Attempt to reach [sip:10000@192.168.0.200] failed. Reason: Not Found
    01:19:22.500 CallCtrl::eek:nSelectRouteReq [CM503013]: Call(1): No known route to target: [sip:10000@192.168.0.200]
    01:19:22.500 MediaServerReporting::SetRemoteParty [MS210000] C:1.1:Offer received. RTP connection: 192.168.0.200:8000(8001)
    01:19:22.484 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:10000@192.168.0.200]
    01:19:22.484 CallLeg::setRemoteSdp Remote SDP is set for legC:1.1
    01:19:22.484 Extension::printEndpointInfo [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NCH Swift Sound Express Talk 3.04] Transport: [sip:192.168.0.200:5060]
    01:19:22.453 CallCtrl::eek:nIncomingCall [CM503001]: Call(1): Incoming call from Ext.101 to [sip:10000@192.168.0.200]
    01:19:22.453 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:10000@192.168.0.200 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.196:5060;rport=5060;branch=z9hG4bK22255
    Max-Forwards: 20
    To: [sip:10000@192.168.0.200]
    Call-ID: 1205715490-255-Layth%20Hamza%E2%80%99s%20MacBook%20Pro@192.168.0.200
    CSeq: 288 INVITE
    Proxy-Authorization: Digest username="101",realm="3CXPhoneSystem",nonce="12850190361:35f5d300bd9854b2cce8e2c2979df580",uri="sip:10000@192.168.0.200",response="06d854059c72b74b888afbe0622c4c6a",opaque="",algorithm=MD5
    Supported: replaces
    Content-Length: 0
    01:19:19.171 ListenConnect SL: connected telephone:0/PHPExtension_0 at [telephone]/PHPExtension_0
