SIPGate Outgoing Call No Sound
Discussion in '3CX Phone System - General' started by jas07, Mar 23, 2009.
  1. jas07
    Mar 23, 2009
    28
    Hi Guys,
    Ive got a problem in that outgoing calls using SipGate have no sound, calling the sipgate test number is just silent.
    Ive ran the firewall test and everything is coming back fine, ive also for the sake of testing things ran 3CX on DMZ and this made no difference at all. Incoming calls are fine but just going outgoing have the problem.
    Anyone got any ideas?
    Jas
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Got the correct codecs listed in the VOIP providers properties?
    What is the 3CX log showing you?
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,915
    223
    This is 100% a firewall configuration problem or possibly your ISP blocking certain ports or having 'double nat'....
  4. jas07
    Mar 23, 2009
    28
    Having had a search on here i thought it to be firewall as well, however ive put it in DMZ and it made no difference. My ISP doesnt block any ports either which makes life slightly easier as i can count that out.
    Other VOIP Providers work perfectly, its just SIPGate that has the problem :shock:
