Sipgate Trunk, incomign calls doesn´t work!
Discussion in '3CX Phone System - General' started by Saschavi, Sep 26, 2010.
  1. Saschavi
    Sep 26, 2010
    Hey together,
    Im absolutly Newbie in 3CX.
    Many threads helping me in the German Board.
    But now i have a Problem:
    Im finish with outgoing Connections,but when iam Call the Number from SIPGATE ( My Number).
    It is occupied.
    Iam using Windows7 , because before i took it on a Windows Server i want to test it.
    Logfile:
    Code:
    18:09:56.442  [CM302001]: Authorization system can not identify source of: SipReq:  INVITE 4918010121329226@188.195.233.94:1024 tid=24fb.bb6a2b61.0 cseq=INVITE contact=anonymous@217.116.117.69 / 103 from(wire)
    18:09:45.226  [CM504004]: Registration succeeded for: 10000@colorhost
    18:09:44.927  [CM504003]: Sent registration request for 10000@colorhost
    18:09:40.463  [CM504004]: Registration succeeded for: 10000@colorhost
    18:09:40.182  [CM504003]: Sent registration request for 10000@colorhost
    18:09:33.619  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      INVITE sip:4918010121329226@188.195.233.94:1024;rinstance=907d704c19f5b76e SIP/2.0
      Via: SIP/2.0/UDP 217.10.68.150:5060;branch=z9hG4bK005f.c949a823.0
      Via: SIP/2.0/UDP 172.20.40.6;branch=z9hG4bK005f.c949a823.0
      Via: SIP/2.0/UDP 217.10.68.150:5060;received=217.10.68.178;branch=z9hG4bK3716aefc
      Via: SIP/2.0/UDP 217.116.117.70:5060;received=217.116.117.70;branch=z9hG4bK3716aefc;rport=5060
      Max-Forwards: 67
      Record-Route: <sip:217.10.68.150;lr=on;ftag=as69448a61>
      Record-Route: <sip:172.20.40.6;lr=on>
      Contact: <sip:anonymous@217.116.117.70>
      To: <sip:004918010121329226@sipconnect.sipgate.de>
      From: "anonymous"<sip:anonymous@sipconnect.sipgate.de>;tag=as69448a61
      Call-ID: 628b2f9d6cb106195b64827d1cdcfa11@sipconnect.sipgate.de
      CSeq: 103 INVITE
      Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
      Supported: replaces
      Content-Length: 0
      X-LEGID: 47694dc4
    Hope u can help me
    Regards
    Sascha
  2. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    For Sipgate I just use in settings server or hostname= sipgate.co.uk Leave outbound proxy blank. This means that you need to tell it the WAN IP address on the advanced TAB. You could use STUN, but I find static IP much more stable. Obviously you need a static IP from your ISP.
    I hope that helps
    Kind regards
    Richard
