SIPIP6000 BLF For Shared Parking
Discussion in '3CX Phone System - General' started by davidc@allpax.com, Apr 30, 2015.
  1. davidc@allpax.com
    Jun 25, 2014
    15
    I am trying to get the shared parking to show up in the Polycom IP6000 conference phone. I have updated to the latest firmware and the BLFs are configured in the management console, but they do not show up on the phone.
  2. Leonidas 3CX
    3CX Support
    May 6, 2015
    12
    Hello David,
    Please make sure that after you perform the changes on the management console to press the apply button on the bottom of the page. Also Under extensions>>rights>> enable the allow parking option.
    After the changes reset and reprovision the phones via the management console.
    Thank you,
    Leonidas
  3. davidc@allpax.com
    Jun 25, 2014
    15
    The phone has been reprovisioned, but parking is really not the issue. I cannot get any blfs to load through 3cx. The blfs on the phone do not update.
  4. Thomas 3CX
    3CX Support
    May 6, 2015
    15
    You are using some custom or the default template for the Polycom IP6000 ?
    Thanks,
    Thomas
  5. davidc@allpax.com
    Jun 25, 2014
    15
