SipToSis and Skype Drop Outs
Discussion in '3CX Phone System - General' started by toddwilner, Mar 15, 2009.
  1. toddwilner
    Jan 28, 2009
    5
    I have installed SipToSis and can dial in and out through Skype but as soon as the line is picked up on the other end the call fails and diverts to voicemail. Please help.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    170
    Can you check extension settings? Do you have some forwarding rule that goes to Voicemail? Confirm this first.
    Also make sure that you have correct audio drivers on the machine that you have skype installed.
    Can you see something in server activity log? We need to see why it is sending to voicemail.
    The skype should forward blindly to the extension the line is forwarded too.
