Solved SIPtrunk to Cloud PBX 15.5
Discussion in '3CX Phone System - General' started by business54, Jul 12, 2017.
  1. business54
    Apr 20, 2016
    68
    12
    The SIPtrunk is registered to the system and we can make calls out. I have the trunk set to ring to a ring group but when the call comes in it rings for a split second then goes directly to a mailbox. If I change the destination to IVR, inbound calls flow to the IVR fine. If I change the destination to a known working extension the call rings for a split second then goes to voicemail. Also if I dial the code (800) for the ring group it does ring all phones and roll after 20 seconds to the IVR as programmed. I removed the SIP trunk and ring group and rebuilt them to no-avail. This setup did work until yesterday when the Google server became unresponsive and we had to reset it.
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,609
    243
    And the logs say....?
  3. business54
    Apr 20, 2016
    68
    12
    To ring group:
    07/12/2017 2:10:22 PM - [CM503003]: Call(C:76): Call to <sip:205@customer.3cx.us:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
    07/12/2017 2:10:22 PM - [CM503003]: Call(C:76): Call to <sip:205@customer.3cx.us:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5080
    07/12/2017 2:10:22 PM - [CM503003]: Call(C:76): Call to <sip:201@customer.3cx.us:5060> has failed; Cause: 487 Request Cancelled/INVITE from x.x.x.x:24032
    07/12/2017 2:10:22 PM - [CM503003]: Call(C:76): Call to <sip:200@customer.3cx.us:5060> has failed; Cause: 487 Request Cancelled/INVITE from x.x.x.x:55172
    To 1 extension:
    07/12/2017 2:11:49 PM - [CM503003]: Call(C:77): Call to <sip:205@customer.3cx.us:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
    07/12/2017 2:11:49 PM - [CM503003]: Call(C:77): Call to <sip:205@customer.3cx.us:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5080
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Make sure that the extensions in the Ring group are set to available. Also check in case any extensions has ring my mobile simultaneously as the phone might be dropped by the carrier if the call is going out. If you have the ability to open a ticket please do as we will need to see a wireshark capture as well as the matching logs of the PBX to see why the call is being dropped.
  5. business54
    Apr 20, 2016
    68
    12
    Ticket opened:
    #148508
  6. business54
    Apr 20, 2016
    68
    12
    I found the resolution here: https://support.siptrunk.com/hc/en-...X-IP-PBX-V15-SIPTRUNK-com-Trunk-Configuration
    The default template sets the Host as: gw.siptrunk.com
    At this stage, many of the configuration settings have automatically been filled in for you, but it is still necessary to configure your account based on your needs. Most specifically:
    • Registrar/Server/Gateway Hostname or IP: gw1.siptrunk.com and port 5060.
    I changed to gw1.siptrunk.com and calls flow as expected.
  7. YiannisH_3CX
    May 10, 2016
    7,400
    535
    Glad to hear the issue is resolved :)
