Sipura 3000 as FXO Gateway
Fallout
I was wondering if anyone is successfully using a Sipura 3000 as a FXO Gateway.I was hoping not to spend up big on a FXO Gateway as I have only one PSTN line in.Was hoping someone had one of these working and would share their config.
Sipura 3000
Did you have any luck with this one? If you have it i suggest you try it. Be sure to check that it is an FXO gateway, not an FXS gateway. If you have problems let us know - you could mail us the config screenshots and we could help.
I have a Sipura 3000 (1xFXO 1xFXS) box on the Australian Engin network (http://www.engin.com.au). Unfortunately it's locked to Engin right now so I can't get in there and reconfigure for 3CX. Will advise when I can.
I do have an unlocked Sipura 2000 (2xFXS) ATA (linksys PAP2/T). It works with 3CX just fine.
Cheers all.
Rgds, Mark.
Getting Started - Admin
Ramishvohrw
Get 3CX - Absolutely Free!
3CX
