Sipura SPA1001
Discussion in '3CX Phone System - General' started by retailx, Apr 18, 2007.
  1. retailx
    Aug 23, 2006
    27
    Hi, can anyone tell me if this system is compatible or can be used with 3CX system requiring access to and control of a PSTN line as well as VOIP provider? The unit has an 1XLAN/Ethernet port and a port for connecting to telephone.
  2. brianfpmoab
    Mar 15, 2007
    17
    retailx,
    I currently have 12 SPA1001 connected to 3CX just fine. I have 9 PSTN lines via 3 PSTN gateway devices.
    You will need another device (FXO) to connect to PSTN line, such as a VoIOP gateway, besides the SPA1001. Here is a link to some recommended gateways.
    http://www.3cx.com/support/voip-gateways.html
    I am unfamiliar with VoIP providers, so I am no help there.
    The SPA1001 was very easy to configure to work with 3CX.
    Hope this helps.
    Brian
