Sizing VM for Vmware debian image
Discussion in '3CX Phone System - General' started by max999, Dec 17, 2016.
  1. max999
    Jan 10, 2016
    11
    I did not found the hardware sizing (RAM - CPU - harddrive) for the Debian VM Installation?
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    833
    127
  3. max999
    Jan 10, 2016
    11
    That mean the windows system needs the same ressouces as the Linux, that could not be right?
  4. iwatts
    Jan 28, 2011
    "less" would be fine.
    My Jessie VPS on OVH chews 8.9G, includes a Unifi controller and 3CX.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,486
    357
    Obviously each system uses and needs different specifications depending on use and size. For example someone with 20 extensions and no call recordings does not need the same amount of storage as someone with call recordings. It is always best to overestimate and be on the safe side than finding your resources not being enough.
  6. 3cxBora
    Jun 17, 2015
    35
    We have testing 3cx v15 Linux on ESXi 6.0 using local RAID1 SATA drives, 2 GB RAM and 4 vCPU (2 socket) for 12 extension with 8SC.
    One the issue is intermittent drop connection from remote phone via VPN. VPN is working when we noticed "no service" on the Yealink phone and after 1 minutes, the Yealink is connected again and runs normal.
    We other another VM on the same VMware ESXi running Windows 2012 r2 without any issue or does not have drop connection. The ESXi server has 32 GB RAM and are not all allotted.
    We are still trying to figure it is 3cx Linux or NIC driver or something else causing the issue.
    Anyone running 3cx on VMware ESXi and want to share their configuration?
    Thanks in advance for your feedback,
    Bora
  7. max999
    Jan 10, 2016
    11
    I have VMware 6. And I am installing the Debian Image. I have the Problem that the vm has DHCP and I want fixed IP address - but in the Installation process - the IP settings can not be changed. And when the installation is ready - the web console is desployed with the wrong address?
  8. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
  9. max999
    Jan 10, 2016
    11
    why should we use the standard Image when there is also a special Image from 3cx? we hat yet installed the 3CX Software on a Windows System and want to migrate to the Linux Image.
  10. 3cxBora
    Jun 17, 2015
    35
    one of the issue I noticed on 3cx Linux is the error:
    "Web server is not responding to requests. Contact administrator"
    I have refresh the browser or change the URL to the default home webconole to resolve the issue.
