Skinning for Phone
Discussion in 'Windows' started by waxxed, Dec 29, 2009.
  1. waxxed
    Dec 29, 2009
    Is skinning documentation/sdk available now? IF not, I have seen someone mentioned you can combine bitmaps and ini file into skin if we send it to you, can you share the details of graphic elements that are part of 3CX Voip Pone skin?
    Thanks!
    Waxx
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,422
    61
    Right now is not possible - soon we will release a new version of 3CXphone supporting video and, accordingly, the skin and its parameters will be changed.
    Regards
    vali
  3. waxxed
    Dec 29, 2009
    thanks for your answer, do we know the estimated date for that release?
    Thanks,
    W
  4. leejor
    10,360
    226
    Wow, that is great news given the number of Laptops and Netbooks out there with built in cameras (and the low cost of the add-on cameras). Looking forward to trying it out.
