skype connect gateway problems
Discussion in '3CX Phone System - General' started by vdtluke, Dec 19, 2011.
  1. vdtluke
    Dec 19, 2011
    3cx v 10.0.22686.2297
    2 software 3 cx phones
    1 polycom 335 sip 4.0.1.13681, boot 3.0.2.0024
    2 polycom 500 sip 2.1.3.0028 , boot 2.5.0.006
    presently have 3 online numbers, 1 is registered to 3CX and appears to work correctly, outgoing calls work fine every time, inbound calls seem to work 50 % of the time, when a call comes in its transferred correctly and the phones ring however when it doesnt work after 2 rings it states the person im trying to reach is currently unavilable this does not sound like a 3CX voice prompt rather a skype answer, the firewall check is below
    3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
    <10:11:53>: Phase 1, checking servers connection, please wait...
    <10:11:53>: Stun Checker service is reachable. Phase 1 check passed.
    <10:11:53>: Phase 2a, Check Port Forwarding to UDP SIP port, please wait...
    <10:11:53>: UDP SIP Port is set to 5060. Response received WITH TRANSLATION 44868::5060. Phase 2a check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    <10:11:53>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
    <10:11:53>: TCP SIP Port is set to 5060. Response received WITH TRANSLATION 44868::5060. Phase 2b check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    <10:11:53>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
    <10:11:53>: TCP TUNNEL Port is set to 5090. Response received WITH TRANSLATION 44898::5090. Phase 3 check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    <10:11:53>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
    <10:11:59>: UDP RTP Port 9000. Response received WITH TRANSLATION 48808::9000. Phase 4-01 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    <10:11:59>: UDP RTP Port 9001. Response received WITH TRANSLATION 48809::9001. Phase 4-02 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    <10:11:59>: UDP RTP Port 9002. Response received WITH TRANSLATION 48810::9002. Phase 4-03 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    <10:11:59>: UDP RTP Port 9003. Response received WITH TRANSLATION 48811::9003. Phase 4-04 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    <10:11:59>: UDP RTP Port 9004. Response received WITH TRANSLATION 48812::9004. Phase 4-05 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    <10:11:59>: UDP RTP Port 9005. Response received WITH TRANSLATION 48813::9005. Phase 4-06 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    <10:11:59>: UDP RTP Port 9006. Response received WITH TRANSLATION 48814::9006. Phase 4-07 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    <10:11:59>: UDP RTP Port 9007. Response received WITH TRANSLATION 48815::9007. Phase 4-08 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    <10:11:59>: UDP RTP Port 9008. Response received WITH TRANSLATION 48816::9008. Phase 4-09 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
    so my questions are as follows, could there be a routing issue that is cuasing the gateway to "pickup" the call sometimes and not others? and second is if i register another online skype connect account to my SIP profile is there a way in 3CX to direct that specfic phone number to a different set of extensions, eg, one number goes to one department one goes to another department? thanks alot.
  2. vdtluke
    Dec 19, 2011
    forget to mention logging set to verbose mode and when the call "fails" nothing appears in the log
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    813
    46
    Make sure you have setup your router correctly. The Firewall Checker MUST end without any problem to can go on.
    Read these How-To articles
    http://www.3cx.com/blog/voip-howto/firewall-nat-pat-stun/
    http://www.3cx.com/blog/voip-howto/router-firewall-features-requirements/
