Skype Connect Issue.
Discussion in '3CX Phone System - General' started by successph, Jul 15, 2014.
  1. successph
    Jul 15, 2014
    I try to make an outgoing call but no luck. Can someone help me to check what went wrong in my configuration..Thanks in advance.
    15-Jul-2014 10:26:15.154 Leg L:8.1[Extn] is terminated: Cause: BYE from PBX
    15-Jul-2014 10:26:15.103 [CM503020]: Call(C:8): Normal call termination. Call originator: Extn:1000. Reason: No answer
    15-Jul-2014 10:26:15.103 Leg L:8.2[Line:10000>>639151496581] is terminated: Cause: 408 Request Timeout/INVITE from local
    15-Jul-2014 10:26:15.103 L:8.1[Extn] failed to reach Line:10000>>639151496581, reason No Answer
    15-Jul-2014 10:26:15.103 Call to T:Line:10000>>639151496581@[Dev:sip:99051000241438@sip.skype.com:5060] from L:8.1[Extn] failed, cause: Cause: 408 Request Timeout/INVITE from local
    15-Jul-2014 10:26:15.103 [CM503003]: Call(C:8): Call to <sip:639151496581@sip.skype.com:5060> has failed; Cause: 408 Request Timeout/INVITE from local
    15-Jul-2014 10:25:59.073 Currently active calls - 1: [8]
    15-Jul-2014 10:25:43.042 [CM503025]: Call(C:8): Calling T:Line:10000>>639151496581@[Dev:sip:99051000241438@sip.skype.com:5060] for L:8.1[Extn]
    15-Jul-2014 10:25:42.693 [CM503027]: Call(C:8): From: Extn:1000 ("1000" <sip:1000@192.168.1.51:5060>) to T:Line:10000>>639151496581@[Dev:sip:99051000241438@sip.skype.com:5060]
    15-Jul-2014 10:25:42.693 [CM503004]: Call(C:8): Route 1: from L:8.1[Extn] to T:Line:10000>>639151496581@[Dev:sip:99051000241438@sip.skype.com:5060]
    15-Jul-2014 10:25:42.693 Line limit check: Current # of calls for line Lc:10000(@Skype[<sip:99051000241438@sip.skype.com:5060>]) is 0; limit is 1
    15-Jul-2014 10:25:42.693 Call(C:8): Call from Extn:1000 to 639151496581 matches outbound rule 'Rule for Skype'
    my phone is doesn't ring anyway.
    11,133
    331
    So...the trunk is showing as registered?
    What happens when you dial your Skype number (attempt a call into the PBX), Do you get a log showing the incoming call?
    Are you sending the correct digits to Skype?
  3. successph
    Jul 15, 2014
    Thanks for the reply leejor...
    the trunk shows registered. I am trying to call my cellphone number using 3cx softphone. in the 3cx softphone it say that dialing but after a minute hook up again..upon checking to the server logs it says no answer but my phone is not ringing anyway. i dont know where is the problem anymore why it doesn't work out the way it should be.
  4. successph
    Jul 15, 2014
  5. leejor
    11,133
    331
    You say that you are trying to call your cellphone, but, have you completed a successful call (over Skype) to any other number?
    You didn't answer my question about sending the correct digits. Is there any sort of prefix that Skype requires?
    See...https://support.skype.com/en/faq/FA10573/what-format-should-my-dial-plan-be-in
