Skype Connect no inbound?
Discussion in '3CX Phone System - General' started by jmd87, Sep 23, 2014.
  1. jmd87
    Sep 23, 2014
    I have just started using 3CX after using Trixbox for past 4 years and have found most of 3CX fantastic except I have run into an issue where I can call outbound from 3CX using a Skype Connect Trunk but I can't call inbound. I have followed some on the tutorials and other things people have tried on the forums but I just can't seem to get it to work at all
    Can anyone advise please?
    Kind Regards
    Joe
    11,111
    329
    Have a look at the 3CX Server log. Hopefully it shows an inbound call, and may provide a clue as to why it's not going where you want it to. If you are still stuck, post the log showing a call.
  3. jmd87
    Sep 23, 2014
    thanks alot it was to do with a port i hadn't enabled properly!
    Thanks again
    Joe
