- Joined
- Sep 24, 2010
- Messages
- 11
- Reaction score
- 0
Ok, I am getting confused spending a whole day just to configure this Skype for SIP VoIP gateway.
I have a fully working 3CX Phone System installed on a Windows XP machine. I had already tested that the phone system is working by setting up 3CX Gateway for Skype (http://www.3cx.com/voip-gateways/skype/) couple of weeks ago.
My new job is to make this Skype for SIP working over the 3CX Phone System. I've reset all of the past 3CX Configuration and setup a new one.
This is what I've done so far:
•I'm using 3CX v.9!
•Put the Windows XP machine where the 3CX Phone System was installed on a Public IP Address.
•Configured my Polycom SoundPoint 320 SIP IP Phone and registered it to the 3CX Phone System with the extension number of 101. (http://www.3cx.com/sip-phones/polycom-soundpoint)
•Setup a Skype Manager account and create a Skype SIP Profile including 1 Channel, Outgoing Calls, Caller ID & Incoming number/calls.
•Successfully registered the Skype SIP Profile to my 3CX Phone System.
Problem is, when I tried to call my Incoming number (or Caller ID, I don't know, I'm confused) provided by Skype using my landline I can only hear 2 ringing tones followed by a Disconnected tone on my landline phone but my SIP IP Phone with extension number of 101 did not rang at all. And when I use my SIP IP phone with extension number 101 to call a US-based cell phone, it immediately responses for a busy/disconnected tone.
I had already got in touch with a Skype Chat Support and after couple of hours of our conversation, it only resulted that the real problem is within my end. They told me that they can also dial my Incoming number provided by Skype and heard it ringing on their side but after a couple of rings, the ringing also get disconnected.
I have attachedthe most basic configuration that I've made on my 3CX Phone System & Polycom IP Phone.
I'm getting this log when I tried to dial my Incoming number using my landline.
12:29:20.265 Requests rate from IP 204.9.161.164 is too high! Blacklisted for 21 seconds
12:29:20.265 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
INVITE sip:[email protected]:5060;rinstance=c8e92f5821d6c100;transport=udp SIP/2.0
Via: SIP/2.0/UDP 204.9.161.164:5060;branch=z9hG4bK-775d7-4caaa965-f1c4014e-5b00bac4
Max-Forwards: 30
Contact: <sip:[email protected]:5060;transport=udp>
To: <sip:[email protected]>
From: <sip:[email protected]>;tag=a4a109cc-13c4-4caaa965-f1c4014e-3ed741d7
Call-ID: CXC-172-68089770-a4a109cc-13c4-4caaa965-f1c4014e-24ae8b71
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE
User-Agent: SipGW 0.3.20
P-Asserted-Identity: <sip:sip.skype.com>
Content-Length: 0
12:29:20.250 [CM302001]: Authorization system can not identify source of: SipReq: INVITE [email protected]:5060 tid=-775d7-4caaa965-f1c4014e-5b00bac4 cseq=INVITE [email protected]:5060 / 1 from(wire)
And this is what I'm getting when using my Polycom IP Phone to dial a US-based cell phone.
12:36:16.406 [CM503020]: Normal call termination. Reason: Not available
12:36:16.406 [CM503016]: Call(1): Attempt to reach <sip:[email protected];user=phone> failed. Reason: Not Registered
12:36:16.390 [CM503017]: Call(1): Target is not registered: Out.0013046736492{rule=Rule for Skype SIP}
12:36:16.328 [CM503010]: Making route(s) to <sip:[email protected];user=phone>
12:36:16.312 [CM505001]: Ext.101: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_320-UA/2.1.2.0049] PBX contact: [sip:[email protected]:5060]
12:36:16.296 [CM503001]: Call(1): Incoming call from Ext.101 to <sip:[email protected];user=phone>
and for random reason, I'm getting this error on my log.
12:53:15.890 Blacklisted (Too many failed auth)IP = 127.0.0.1:6060; Failed auth: 25; unauth: 26; auth: 25
12:52:54.656 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=e078060004668e23 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:52:33.140 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=e557423eff407733 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:52:11.609 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=9c3da32f935de763 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:51:50.093 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=42007a7b70178e15 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:51:28.562 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=0d0ab717943ac72d cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:51:07.031 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=ec7b7b252c35d004 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:50:45.515 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=5d2650220e38c655 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:50:23.984 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=fb76d543b1198374 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:50:02.453 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=ad23d31ad44b8d0e cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:49:40.937 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=9c201704321ab16f cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:49:19.406 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=5e5c8f48ed480a78 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:48:57.890 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=f565776b9f137a78 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:48:36.359 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=931294543112e553 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:48:14.828 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=4605d115e336aa5e cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:47:53.312 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=f430c34e30013353 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:47:31.781 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=511dd4756e338d21 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:47:10.359 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=b571276659656a31 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:46:48.828 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=fd1c784af4430031 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:46:27.312 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=d86f8428593f9610 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:46:05.781 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=3737b43d7561c921 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:45:44.250 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=b0662e5dc21ccb4a cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:45:22.734 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=193f6f607e202929 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:45:01.203 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=a7231c4fee37dc2c cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:44:39.671 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=4f10b577af7cb073 cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12:44:18.156 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=426e3e1a24404b4e cseq=REGISTER [email protected]:6060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
Polycom SoundPoint IP320 SIP Line 1 Configuration from 3CX Site
Extension 101 Configuration
Skype for SIP VoIP Gateway/Trunk Configuration
•I'm using 3CX v.9!
Max-Forwards: 30
CSeq: 1 INVITE
Content-Length: 0
