Skype Gateway and Digital Receptionist
Discussion in '3CX Phone System - General' started by gary2seven, Dec 1, 2010.
  1. gary2seven
    Sep 18, 2009
    48
    I have setup a Skype account for our company and want to use that to allow customers to call us via Skype. I have the Skype Gateway installed and working and I have the VOIP provider configured (3CX Version 9 SP4).
    I have setup an inbound rule that passes Skype calls to the Digital Receptionist, exactly the same as the PSTN does.
    However when I use Skype to connect I can't get the 3CX to recognize the selected option.
    In Skype (version 4.2.0.187) I have tried using the keys on my laptop, the Skype key pad, but no success, any ideas?
    Gary.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi Gary,
    This is quite abnormal behaviour, the only way I could provide you with support on the matter is to open up a ticket on support.3cx.com, that is only if you have a support contract. Once you do that I will send you the intruction to collect certain data.
  3. gary2seven
    Sep 18, 2009
    48
    We currently have a support contract through Voipon.co.uk, however that expires at the weekend, currently waiting for prices from 3CX UK to renew direct with you. Once I have contract I will raise a ticket.
    Gary.
