Skype Gateway can't transfer key input from phone.
Discussion in '3CX Phone System - General' started by kuyaz, Apr 7, 2010.
  1. kuyaz
    Apr 7, 2010
    I am having problem with key input during the extension transfer.
    ie. I call a call center. they have menu like press 1 for English press 2 for ....
    I tried to press 1 or 2 but they simply can't get my input at all.
    so I am always stuck at the menu.
    I tried with the hardphone (via Linkysys ATA) and softphone (X-lite) but both don't really work either.
    However, Skype software has no problem at all.
    Can you please solve this as it is very critical to make a proper call?
    Thanks!
  2. kuyaz
    Apr 7, 2010
    FYI,
    with the same system and configuration, I have no problem with SIP Trunk.
    It only happen to Skype 3CX Gateway.
    Thanks.
  3. lotsu99
    Jan 1, 2008
    27
    HI~
    Please use the "inband DTMF " and try it again .
    best regards,
