Skype Gateway - How to choose outgoing line if busy
Discussion in '3CX Phone System - General' started by qz, Aug 26, 2009.
  1. qz
    qz
    May 12, 2009
    10
    Heya,
    Is there any way I can set 3CX up to route outbound calls based on the status of the skype line?
    I'll explain...I have 4 skype accounts, each with credit. You can only use one subscription service at a time when using the same skype username. I would like 3CX to try the first Skype account, if that is busy (i.e someone else is on a call using a subscription service) I would like 3CX to try the next line (skype account) etc.
    Hope that makes sense.
    Dave
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    You can setup fail over options in your outgoing dial plan.
