Skype gateway produces just noise
Discussion in '3CX Phone System - General' started by akito, Sep 13, 2009.
  1. akito
    Sep 9, 2009
    11
    I'm having a problem with my 3CX system together with the Skype gateway.
    Incoming calls from Skype get perfectly well forwarded to my landline, but as soon as I pick up all I can hear is an electrical loud noise. Voice doesn't get passed through in both ways.
    Does anyone have any idea what could be wrong here?
    Just in case, this is the a snippet from the log:
    Code:
    13:31:13.764  [CM503008]: Call(12): Call is terminated
    13:31:07.655  [CM503007]: Call(12): Device joined: sip:xxxxx@sip.poivy.com:5060
    13:31:07.624  [CM503007]: Call(12): Device joined: sip:10004@127.0.0.1:6060
    13:31:02.608  [CM505003]: Provider:[Poivy] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:10.0.0.121:5060]
    13:31:02.608  [CM503002]: Call(12): Alerting sip:xxxxx@sip.poivy.com:5060
    13:31:02.311  [CM503024]: Call(12): Calling VoIPline:1234567890@(Ln.10000@Poivy)@[Dev:sip:xxxxx@sip.poivy.com:5060]
    13:31:02.139  [CM503004]: Call(12): Route 1: VoIPline:1234567890@(Ln.10000@Poivy)@[Dev:sip:xxxxx@sip.poivy.com:5060]
    13:31:01.561  [CM503010]: Making route(s) to <sip:10@10.0.0.121:5060>
    13:31:01.561  [CM505002]: Gateway:[Skype] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:127.0.0.1:5060]
    13:31:01.499  [CM503001]: Call(12): Incoming call from xxxxx@(Ln.10004@Skype) to <sip:10@10.0.0.121:5060>
    Please help me.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Could you please provide more information about "sip:xxxxx@sip.poivy.com:5060"?
    Skype gateway DOES NOT "produces just noise", sorry.
  3. akito
    Sep 9, 2009
    11
    Well, the sound coming out of the speaker I do experience as electrical noise.
    sip:xxxxx@sip.poivy.com:5060 -> xxxx refers to my login account at poivy.com.
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    If you have any kind of information requested in http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html then please extend your post.
    Thanks in advance
  5. akito
    Sep 9, 2009
    11
    I'm sorry but that link asks for, more or less, the information I've already put in my first post.
    What I can do is to try to record the noise I'm hearing, to perhaps make it more clear.
    Voip provider is poivy (one of those betamax things), gateway is the 3CX provided Skype gateway. I'm not using any SIP phones as I'm simply forwarding all incoming calls, to my landline. Note: incoming calls from through Eutelia (italian), Budgetphone (Dutch) and TPAD (UK?) works perfectly fine. It's only the Skype-part that's giving me troubles.
  6. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,416
    58
    Hi Akito
    Akito, your skype gateway is installed and running on a virtual machine?
    Regards
    vali
  7. akito
    Sep 9, 2009
    11
    That's correct. And I've tried with and without a virtual audio driver, without any luck.
  8. Vali_3CX
    Dec 12, 2008
    1,416
    58
    Hi, Akito
    Somewhere here on the forum, on the Skype Gateway section, I warned about VM issue.
    Briefly, when you move the mouse inside the VM desktop, you will easily observe that it moves much slower and "bumpy" than on the real, physical desktop.
    This "bumpy" behavior happens also on the audio, on ports, on internet traffic, on processor, since all hardware resources are virtualised, "translated" by VM. If my machine has a 10 MB network card, by running 3VMs simultaneously on it doesn't mean I got a gain to 40MB, but to fit more than 4 times more traffic into the real available 10 MB, with coresponding trade-off.
    Regards
    vali
  9. mattjuna
    Oct 11, 2009
    I had a similar problem, as soon as a call went through all I got was a loud noise.
    I later found the problem was that the audio driver on the server i was using did not appear to be installed correctly. I re-installed the driver and the skype gateway worked perfectly.
