skype gateway
Discussion in '3CX Phone System - General' started by mitcholson11, Jul 21, 2011.
  1. mitcholson11
    Jul 21, 2011
    Using the demo version of 3CX, I'm trying to setup multiple Skype accounts with great trouble. I can get either one to register by setting one as a master, but never both. I hope somebody can help!
    See attachment for details.
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Your trying to use the same account multiple times. Use a different account for the second trunk. Or even better, don't use the Skype Gateway as it really isn't a supported product anymore.
  3. mitcholson11
    Jul 21, 2011
    They are different Skype accounts. In my opinion, the Skype Gateway is much more economical than Skype's VoIP service ($29/year/account for gateway vs $7/month/account VoIP), so I'd prefer to go that route.
