Skype now offering SIP?
Discussion in '3CX Phone System - General' started by leejor, Dec 9, 2009.
  1. leejor
    10,360
    226
    I had an email from Skype the other day and it looks like they are, or will soon be, offering SIP, from what I gather, for businesses only.
    Didn't really delve into it but it seems that Skype is looking to expand their customer base.
    Came across the link to it...http://www.skype.com/intl/en/business/products/pbx-systems/sip/get-it-now/#paddedContent
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    663
    Yes, for money. But 3CX Gateway is free. :lol:
  3. mike.petersen
    Sep 14, 2009
    8
    Has anyone tried this out? I'm currently working on setting up incoming/outgoing calls with the 3cx Skype Gateway, but am thinking this might be a better option.
  4. MP_Swede
    Feb 5, 2009
    6
    I have Skype for SIP now, incoming calls both landline and from other Skype clients works very well. (Even if it takes 30 sec before it comes to the PBX from Skype clients)
    Outgoing calls I'm still struggling with as I get below error
    12:10:22.634 [CM503008]: Call(28): Call is terminated
    12:10:22.580 [CM503020]: Normal call termination. Reason: Not found
    12:10:22.580 [CM503016]: Call(28): Attempt to reach <sip:0708215965@192.168.2.96> failed. Reason: Not Found
    12:10:22.580 [CM503003]: Call(28): Call to sip:0708215965@sip.skype.com:5060 has failed; Cause: 404 Not Found; from IP:193.120.218.68:5060
    12:10:22.099 [CM503025]: Call(28): Calling VoIPline:0708215965@(Ln.10001@Skype)@[Dev:sip:9905100000xx@sip.skype.com:5060]
    12:10:21.946 [CM503004]: Call(28): Route 1: VoIPline:0708215965@(Ln.10001@Skype)@[Dev:sip:9905100000xx@sip.skype.com:5060]
    12:10:21.942 [CM503010]: Making route(s) to <sip:0708215965@192.168.2.96>
    12:10:21.940 [CM505001]: Ext.500: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [DIP Phone 450010630000000] PBX contact: [sip:500@192.168.2.96:5060]
    12:10:21.937 [CM503001]: Call(28): Incoming call from Ext.500 to <sip:0708215965@192.168.2.96>
  5. MP_Swede
    Feb 5, 2009
    6
    I just notised the line
    Why does it say "Call to sip:*" ?
    On my working SIP trunks I do not get this extra line and they work perfect.
  6. leejor
    10,360
    226
    Could you be sending a number format that they don't accept or just don't understand? The "0" prefix might be a standard within the PSTN network in your country but for Skype you may have to add a few digits to the beginning of your outgoing number.
    http://www.tekelec.com/SIPReferenceGuide/mapping_ISUP_cause_codes_to_SIP-I_SIP-T_responses.asp
