SKYPE Out failing
Discussion in '3CX Phone System - General' started by thames, Sep 4, 2011.
  1. thames
    thames New Member
    Apr 4, 2011
    109
    Hi Folks
    New here. Just installed my first 3CX system as a potential reseller but having trouble getting the system to dial out using the SKYPE (or any other) gateway. When I make a call from the only phone I currently have registered (my iPhone running the Acrobits Groundwire app), I get these two lines in the log file:
    23:31:27.053 [CM503016]: Call(5): Attempt to reach <sip:901344641626@192.168.1.200> failed. Reason: Not Acceptable HereReason Unknown
    23:31:27.042 [CM503003]: Call(5): Call to sip:01344641626@sip.skype.com:5060 has failed; Cause: 484 Address Incomplete; from IP:63.209.144.201:5060
    Can anyone tell me why this is happening and what I need to change to make it work?
    I'm having similar trouble getting calls out to the OrbTalk gateway, except the error is different. I'll address that one in a new post once this one has been solved, with your help.
    Chris
    10,772
    286
    It looks like you are sending incorrect telephone numbers to them. I would review your outbound rules and adjust as necessary .
  3. thames
    thames New Member
    Apr 4, 2011
    109
    Hi Leejor
    Here is a shot of my outbound rule. Could you suggest a change?
    Many thanks
    Chris
  4. leejor
    10,772
    286
    The first log showed a 9 at the beginning, I'm assuming that you then changed the outgoing rule to strip off the 1 digit (the 9). The second log seem to indicate that you are sending an incomplete phone number. I don't know what country you are trying to call or what format Skype Out expects, as I don't use that service. You should contact them for the required digit format and length.
  5. thames
    thames New Member
    Apr 4, 2011
    109
    Thanks - your reply reminded me that SKYPE doesn't want just the national number but requires the country code too. So... I changed the outbound rule to reflect that and it seems to get further (see text from log below). However, when it gets to the actual call stage, there appears to be an issue with credentials. Now - this is what I'm seeing when I use OrbTalk as well. The call appears to go fine and then I get the same error about credentials not matching. Any help here would be sincerely appreciated.
    Chris
    Log extract:
    09:55:57.122 [CM102001]: Authentication failed for SipReq: REGISTER 127.0.0.1:5060 tid=0a66660d6f44cb3e cseq=REGISTER contact=10001@127.0.0.1:6062 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    09:55:43.455 [CM503008]: Call(9): Call is terminated
    09:55:41.293 [CM505003]: Provider:[Skype for SIP - Worldwide] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:99051000144660@87.194.206.168:5060]
    09:55:41.291 [CM503002]: Call(9): Alerting sip:99051000144660@sip.skype.com:5060
    09:55:37.820 [CM503025]: Call(9): Calling VoIPline:00441344412124@(Ln.10000@Skype for SIP - Worldwide)@[Dev:sip:99051000144660@sip.skype.com:5060]
    09:55:37.812 [MS210002] C:9.2:Offer provided. Connection(transcoding mode): 87.194.206.168:9008(9009)
    09:55:37.788 [CM503004]: Call(9): Route 1: VoIPline:00441344412124@(Ln.10000@Skype for SIP - Worldwide)@[Dev:sip:99051000144660@sip.skype.com:5060]
    09:55:37.784 [CM503010]: Making route(s) to <sip:9441344412124@192.168.1.200>
  6. leejor
    10,772
    286
    This happened to someone once before (yours might be a different issue), check that you entered the user info/password directly, not a cut and paste. They did that and introduced an unintended space that went unnoticed.
  7. petrik
    Sep 5, 2011
  8. thames
    thames New Member
    Apr 4, 2011
    109
    Hi Petrik
    Yes I did. But I was trying to get to numeric prefixes rather than the alpha which I also have set up. I have now resolved the SKYPE issue and am making calls out through this gateway just fine. My problem was that I didn't have the outbound rule setup correctly and SKYPE was rejecting the call.
    Many thanks to all.
    Chris
